Run Time: 0.000804
Run Time: 0.000209
WHERE (`xf_thread`.`thread_id` = '40765')
Run Time: 0.000803
WHERE (`xf_post`.`thread_id` = 40765) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002652
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 9 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (654380, 655386, 655389, 655392))
Run Time: 0.002145
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 11 | Using index condition; Using filesort |
Params: 40765
Run Time: 0.000113
Params: 0,
Run Time: 0.000141
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=40765, 1716279333, , 0,
Run Time: 0.000090
WHERE (`xf_session_activity`.`user_id` = 14174) AND (`xf_session_activity`.`unique_key` = '14174')
Run Time: 0.000186
WHERE (`xf_thread_reply_ban`.`thread_id` = 40765) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000199
Run Time: 0.000255
bytes_sent | 12365 |
bytes_received | 287930 |
packets_sent | 124 |
packets_received | 1082 |
protocol_overhead_in | 4328 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 215170 |
packets_sent_command | 61 |
packets_received_change_user | 102 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 84 |
rows_buffered_from_client_ps | 84 |
rows_skipped_ps | 84 |
proto_binary_fetched_bit | 773 |
proto_binary_fetched_short | 177 |
proto_binary_fetched_int24 | 63 |
proto_binary_fetched_bigint | 565 |
proto_binary_fetched_decimal | 35 |
proto_binary_fetched_json | 482 |
proto_binary_fetched_blob | 176 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 213586 |
