Run Time: 0.000643
Run Time: 0.000210
WHERE (`xf_thread`.`thread_id` = '32645')
Run Time: 0.001009
WHERE (`xf_post`.`thread_id` = 32645) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004007
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (491002, 491035, 491036, 491445, 491668, 494676, 495460, 499444, 500699, 501555, 504928))
Run Time: 0.005069
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 13 | Using index condition; Using filesort |
Params: 32645
Run Time: 0.000105
Params: 0, uL
Run Time: 0.000161
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: uL, XF\Pub\Controller\Thread, Index, valid, thread_id=32645, 1716348553, , 0, uL
Run Time: 0.000087
WHERE (`xf_session_activity`.`user_id` = 7828) AND (`xf_session_activity`.`unique_key` = '7828')
Run Time: 0.000172
WHERE (`xf_thread_reply_ban`.`thread_id` = 32645) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000216
Run Time: 0.000211
bytes_sent | 12473 |
bytes_received | 318782 |
packets_sent | 124 |
packets_received | 1091 |
protocol_overhead_in | 4364 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 246022 |
packets_sent_command | 61 |
packets_received_change_user | 111 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 93 |
rows_buffered_from_client_ps | 93 |
rows_skipped_ps | 93 |
proto_binary_fetched_bit | 969 |
proto_binary_fetched_short | 301 |
proto_binary_fetched_bigint | 901 |
proto_binary_fetched_decimal | 37 |
proto_binary_fetched_json | 632 |
proto_binary_fetched_blob | 288 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 244008 |
