Run Time: 0.000810
Run Time: 0.000264
WHERE (`xf_thread`.`thread_id` = '37709')
Run Time: 0.000872
WHERE (`xf_post`.`thread_id` = 37709) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002961
Params: 37709
Run Time: 0.000138
Params: 0, Y
Run Time: 0.000167
Params: Y, XF\Pub\Controller\Thread, Index, valid, thread_id=37709, 1714302798, , 0, Y
Run Time: 0.000147
WHERE (`xf_session_activity`.`user_id` = 42491) AND (`xf_session_activity`.`unique_key` = '42491')
Run Time: 0.000186
WHERE (`xf_thread_reply_ban`.`thread_id` = 37709) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000183
Run Time: 0.000191
bytes_sent | 9840 |
bytes_received | 312246 |
packets_sent | 112 |
packets_received | 880 |
protocol_overhead_in | 3520 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 257467 |
packets_sent_command | 55 |
packets_received_change_user | 92 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 76 |
rows_buffered_from_client_ps | 76 |
rows_skipped_ps | 76 |
proto_binary_fetched_bit | 200 |
proto_binary_fetched_short | 274 |
proto_binary_fetched_bigint | 720 |
proto_binary_fetched_json | 523 |
proto_binary_fetched_blob | 277 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 255764 |
