Run Time: 0.000387
Run Time: 0.000235
WHERE (`xf_thread`.`thread_id` = '46532')
Run Time: 0.001182
WHERE (`xf_post`.`thread_id` = 46532) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001807
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 10 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (795018))
Run Time: 0.001230
SIMPLE | xf_attachment | ref | content_type_id_date,content_type | content_type_id_date | 31 | const,const | 20 | Using index condition; Using where |
Params: 46532
Run Time: 0.000092
Params: 0, K
Run Time: 0.000130
Params: K, XF\Pub\Controller\Thread, Index, valid, thread_id=46532, 1714217539, , 0, K
Run Time: 0.000129
WHERE (`xf_session_activity`.`user_id` = 9521) AND (`xf_session_activity`.`unique_key` = '9521')
Run Time: 0.000165
WHERE (`xf_thread_reply_ban`.`thread_id` = 46532) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000199
Run Time: 0.000172
bytes_sent | 12300 |
bytes_received | 301877 |
packets_sent | 124 |
packets_received | 1094 |
protocol_overhead_in | 4376 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 229076 |
packets_sent_command | 61 |
packets_received_change_user | 114 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 96 |
rows_buffered_from_client_ps | 96 |
rows_skipped_ps | 96 |
proto_binary_fetched_bit | 1339 |
proto_binary_fetched_short | 229 |
proto_binary_fetched_int24 | 77 |
proto_binary_fetched_bigint | 780 |
proto_binary_fetched_decimal | 44 |
proto_binary_fetched_json | 568 |
proto_binary_fetched_blob | 203 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 227179 |
