Run Time: 0.000396
Run Time: 0.000139
WHERE (`xf_thread`.`thread_id` = '24331')
Run Time: 0.000988
WHERE (`xf_post`.`thread_id` = 24331) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003125
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 19 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (335607, 337133))
Run Time: 0.001083
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 2 | Using index condition; Using filesort |
Params: 24331
Run Time: 0.000113
Params: 0,
Run Time: 0.000195
WHERE (`xf_session_activity`.`user_id` = 24815) AND (`xf_session_activity`.`unique_key` = '24815')
Run Time: 0.000160
WHERE (`xf_thread_reply_ban`.`thread_id` = 24331) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000191
Run Time: 0.000182
bytes_sent | 11918 |
bytes_received | 352865 |
packets_sent | 118 |
packets_received | 1073 |
protocol_overhead_in | 4292 |
protocol_overhead_out | 472 |
bytes_received_rset_header_packet | 369 |
bytes_received_rset_row_packet | 123 |
bytes_received_prepare_response_packet | 71491 |
bytes_received_change_user_packet | 280384 |
packets_sent_command | 58 |
packets_received_rset_header | 41 |
packets_received_rset_row | 21 |
packets_received_prepare_response | 885 |
packets_received_change_user | 105 |
result_set_queries | 18 |
non_result_set_queries | 3 |
ps_buffered_sets | 18 |
ps_prepared_once_executed | 18 |
rows_fetched_from_server_ps | 87 |
rows_buffered_from_client_ps | 87 |
rows_skipped_ps | 87 |
proto_binary_fetched_bit | 367 |
proto_binary_fetched_short | 346 |
proto_binary_fetched_int24 | 140 |
proto_binary_fetched_bigint | 924 |
proto_binary_fetched_decimal | 26 |
proto_binary_fetched_json | 657 |
proto_binary_fetched_blob | 339 |
com_stmt_prepare | 19 |
com_stmt_execute | 19 |
com_stmt_close | 18 |
bytes_received_real_data_ps | 278338 |
