Run Time: 0.000408
Run Time: 0.000217
WHERE (`xf_thread`.`thread_id` = '46074')
Run Time: 0.000738
WHERE (`xf_post`.`thread_id` = 46074) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003210
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 21 | Using index condition; Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (784072, 784074, 784080, 784100, 784101, 784123, 784138, 784398, 784399))
Run Time: 0.001638
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 12 | Using index condition; Using filesort |
Params: 46074
Run Time: 0.000100
Params: 0,
Run Time: 0.000158
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=46074, 1714705779, , 0,
Run Time: 0.000164
WHERE (`xf_session_activity`.`user_id` = 37799) AND (`xf_session_activity`.`unique_key` = '37799')
Run Time: 0.000188
WHERE (`xf_thread_reply_ban`.`thread_id` = 46074) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000263
Run Time: 0.000220
bytes_sent | 12432 |
bytes_received | 356063 |
packets_sent | 124 |
packets_received | 1096 |
protocol_overhead_in | 4384 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 283262 |
packets_sent_command | 61 |
packets_received_change_user | 116 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 98 |
rows_buffered_from_client_ps | 98 |
rows_skipped_ps | 98 |
proto_binary_fetched_bit | 946 |
proto_binary_fetched_short | 393 |
proto_binary_fetched_bigint | 1118 |
proto_binary_fetched_decimal | 36 |
proto_binary_fetched_json | 733 |
proto_binary_fetched_blob | 361 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 280914 |
