Run Time: 0.000725
Run Time: 0.000220
WHERE (`xf_thread`.`thread_id` = '41004')
Run Time: 0.000777
WHERE (`xf_post`.`thread_id` = 41004) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003360
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (652487, 652553, 652751, 652867, 652943, 653080, 653290, 653293, 653449, 653500, 653585, 653648, 654350, 654351, 654352, 654353, 654534, 654535))
Run Time: 0.002053
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 26 | Using index condition; Using filesort |
Params: 41004
Run Time: 0.000117
Params: 0,
Run Time: 0.000188
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=41004, 1714633602, , 0,
Run Time: 0.000134
WHERE (`xf_session_activity`.`user_id` = 12855) AND (`xf_session_activity`.`unique_key` = '12855')
Run Time: 0.000161
WHERE (`xf_thread_reply_ban`.`thread_id` = 41004) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000216
Run Time: 0.000217
bytes_sent | 12589 |
bytes_received | 357345 |
packets_sent | 124 |
packets_received | 1109 |
protocol_overhead_in | 4436 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 284585 |
packets_sent_command | 61 |
packets_received_change_user | 129 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 111 |
rows_buffered_from_client_ps | 111 |
rows_skipped_ps | 111 |
proto_binary_fetched_bit | 1804 |
proto_binary_fetched_short | 411 |
proto_binary_fetched_bigint | 1303 |
proto_binary_fetched_decimal | 50 |
proto_binary_fetched_json | 796 |
proto_binary_fetched_blob | 370 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 281955 |
