Run Time: 0.000681
Run Time: 0.000215
WHERE (`xf_thread`.`thread_id` = '34416')
Run Time: 0.000812
WHERE (`xf_post`.`thread_id` = 34416) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004371
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (516190, 516239))
Run Time: 0.001694
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 4 | Using index condition; Using filesort |
Params: 34416
Run Time: 0.000114
Params: 0, ],
Run Time: 0.000197
Params: ],, XF\Pub\Controller\Thread, Index, valid, thread_id=34416, 1714557959, , 0, ],
Run Time: 0.000175
WHERE (`xf_session_activity`.`user_id` = 6277) AND (`xf_session_activity`.`unique_key` = '6277')
Run Time: 0.000194
WHERE (`xf_thread_reply_ban`.`thread_id` = 34416) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000244
Run Time: 0.000260
bytes_sent | 12316 |
bytes_received | 368577 |
packets_sent | 124 |
packets_received | 1088 |
protocol_overhead_in | 4352 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 295776 |
packets_sent_command | 61 |
packets_received_change_user | 108 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 90 |
rows_buffered_from_client_ps | 90 |
rows_skipped_ps | 90 |
proto_binary_fetched_bit | 500 |
proto_binary_fetched_short | 367 |
proto_binary_fetched_bigint | 996 |
proto_binary_fetched_decimal | 28 |
proto_binary_fetched_json | 686 |
proto_binary_fetched_blob | 354 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 293548 |
