One year ago, I knew nothing about Photography and I have been teaching myself ever since. I've been asked to photograph a low key wedding at a registry office on 31st January. It will consist of the bride, the groom and 2 friends. I haven't done a wedding before, they know I am inexperienced but I will be getting paid. They will ask the registry office if flash is allowed and will let me know on Tuesday.
I own the following camera and lenses:
Nikon D5100
Nikon 16-85mm f/3.5-5.6G AF-S DX ED VR Nikkor (Currently in a repair shop!)
Nikon AF-S 50mm f/1.8 G
Tamron SP AF 70-300 F/4-5.6 Di VC
Below is my lighting equipment:
Nikon SB-700 Speedlight
Gary Fong Lightsphere Collapsible (with dome kit)
Westcott 43-inch Umbrella (with removeable black cover)
5-in-1 42" Light Reflector
Lightstand with Interfit STR117 Umbrella & Hotshoe Adapter
I also have a Vista Voyager Tripod with W/FZ10 Head.
I've done a few small jobs and taken family photos using flash. These jobs have always been with my SB-700 on my camera and for most cases, using the Gary Fong Lightsphere. Here is my portfolio if you would like to see (Apologies if this is not allowed, call me a fool if you like but I cannot seem to find the forum rules
). I recently discovered I can trigger my SB-700 using my popup flash. Using the Aokatec A-N1 IR Panel, it stops the pop-up flash from affecting the exposure and only lets Infra-Red Light through. I've tested this with good results.
So out of my equipment, which would you use? Assuming the 16-85mm lens is repaired in time, this is my lens of choice. My only concern is it's not that fast, but if flash is allowed, then this shouldn't be a problem right? I don't have the money to buy/rent faster glass. Would you suggest I hand-hold my camera and use the Gary Fong Lightsphere? Or would it be better to bring along the tripod, and fire flash off camera into an umbrella/reflector? If so, shoot-through or reflective? I'm planning to visit the registery office before the 31st so I can do some test shots.
Thanks for any advice you have.
Nikon D5100
