Run Time: 0.000728
Run Time: 0.000205
WHERE (`xf_thread`.`thread_id` = '42323')
Run Time: 0.000790
WHERE (`xf_post`.`thread_id` = 42323) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001755
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 3 | Using where; Using filesort |
Params: 42323
Run Time: 0.000088
Params: 0, ^
Run Time: 0.000163
Params: ^, XF\Pub\Controller\Thread, Index, valid, thread_id=42323, 1714290153, , 0, ^
Run Time: 0.000133
WHERE (`xf_session_activity`.`user_id` = 45648) AND (`xf_session_activity`.`unique_key` = '45648')
Run Time: 0.000201
WHERE (`xf_thread_reply_ban`.`thread_id` = 42323) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000228
Run Time: 0.000212
bytes_sent | 9840 |
bytes_received | 241477 |
packets_sent | 112 |
packets_received | 868 |
protocol_overhead_in | 3472 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 186698 |
packets_sent_command | 55 |
packets_received_change_user | 80 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 64 |
rows_buffered_from_client_ps | 64 |
rows_skipped_ps | 64 |
proto_binary_fetched_bit | 54 |
proto_binary_fetched_short | 70 |
proto_binary_fetched_int24 | 28 |
proto_binary_fetched_bigint | 194 |
proto_binary_fetched_json | 283 |
proto_binary_fetched_blob | 97 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 185721 |
