Run Time: 0.000747
Run Time: 0.000145
WHERE (`xf_thread`.`thread_id` = '43984')
Run Time: 0.000560
WHERE (`xf_post`.`thread_id` = 43984) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003587
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (721522, 721523, 721524, 721664, 721665, 721666, 721667, 721812, 721813, 721814, 721815))
Run Time: 0.000857
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 11 | Using index condition; Using filesort |
Params: 43984
Run Time: 0.000113
Params: 0, ځd
Run Time: 0.000138
Params: ځd, XF\Pub\Controller\Thread, Index, valid, thread_id=43984, 1714201914, , 0, ځd
Run Time: 0.000122
WHERE (`xf_session_activity`.`user_id` = 12541) AND (`xf_session_activity`.`unique_key` = '12541')
Run Time: 0.000175
WHERE (`xf_thread_reply_ban`.`thread_id` = 43984) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000194
Run Time: 0.000196
bytes_sent | 12464 |
bytes_received | 355355 |
packets_sent | 124 |
packets_received | 1095 |
protocol_overhead_in | 4380 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 282554 |
packets_sent_command | 61 |
packets_received_change_user | 115 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 97 |
rows_buffered_from_client_ps | 97 |
rows_skipped_ps | 97 |
proto_binary_fetched_bit | 894 |
proto_binary_fetched_short | 398 |
proto_binary_fetched_bigint | 1094 |
proto_binary_fetched_decimal | 35 |
proto_binary_fetched_json | 721 |
proto_binary_fetched_blob | 363 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 280242 |
