Run Time: 0.000384
Run Time: 0.000178
WHERE (`xf_thread`.`thread_id` = '45044')
Run Time: 0.000667
WHERE (`xf_post`.`thread_id` = 45044) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003655
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (750255, 750256, 750257, 750258, 750259, 750294, 750295, 750296, 750298, 750299, 750300, 750301, 750387, 750388, 750389, 750390))
Run Time: 0.001311
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 16 | Using index condition; Using filesort |
Params: 45044
Run Time: 0.000096
Params: 0, ;d*
Run Time: 0.000172
Params: ;d*, XF\Pub\Controller\Thread, Index, valid, thread_id=45044, 1714282812, , 0, ;d*
Run Time: 0.000151
WHERE (`xf_session_activity`.`user_id` = 12541) AND (`xf_session_activity`.`unique_key` = '12541')
Run Time: 0.000189
WHERE (`xf_thread_reply_ban`.`thread_id` = 45044) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000222
Run Time: 0.000270
bytes_sent | 12544 |
bytes_received | 355089 |
packets_sent | 124 |
packets_received | 1100 |
protocol_overhead_in | 4400 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 282288 |
packets_sent_command | 61 |
packets_received_change_user | 120 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 102 |
rows_buffered_from_client_ps | 102 |
rows_skipped_ps | 102 |
proto_binary_fetched_bit | 1188 |
proto_binary_fetched_short | 409 |
proto_binary_fetched_bigint | 1164 |
proto_binary_fetched_decimal | 40 |
proto_binary_fetched_json | 746 |
proto_binary_fetched_blob | 368 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 279876 |
