Run Time: 0.000408
Run Time: 0.000159
WHERE (`xf_thread`.`thread_id` = '33037')
Run Time: 0.000518
WHERE (`xf_post`.`thread_id` = 33037) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003098
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (496611, 496612, 496613, 497082, 497083, 500132, 500628, 505683, 505684, 505686, 506482, 506484, 506488))
Run Time: 0.001573
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 39 | Using index condition; Using filesort |
Params: 33037
Run Time: 0.000077
Params: 0,
Run Time: 0.000121
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=33037, 1716268048, , 0,
Run Time: 0.000106
WHERE (`xf_session_activity`.`user_id` = 12541) AND (`xf_session_activity`.`unique_key` = '12541')
Run Time: 0.000142
WHERE (`xf_thread_reply_ban`.`thread_id` = 33037) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000157
Run Time: 0.000144
bytes_sent | 12503 |
bytes_received | 365011 |
packets_sent | 124 |
packets_received | 1123 |
protocol_overhead_in | 4492 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 292251 |
packets_sent_command | 61 |
packets_received_change_user | 143 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 125 |
rows_buffered_from_client_ps | 125 |
rows_skipped_ps | 125 |
proto_binary_fetched_bit | 2571 |
proto_binary_fetched_short | 455 |
proto_binary_fetched_bigint | 1486 |
proto_binary_fetched_decimal | 63 |
proto_binary_fetched_json | 861 |
proto_binary_fetched_blob | 365 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 289331 |
