Run Time: 0.000380
Run Time: 0.000245
WHERE (`xf_thread`.`thread_id` = '2717')
Run Time: 0.000776
WHERE (`xf_post`.`thread_id` = 2717) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002033
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 6 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (21169, 21198))
Run Time: 0.001111
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 2 | Using index condition; Using filesort |
Params: 2717
Run Time: 0.000097
Params: 0, vȈ
Run Time: 0.000161
Params: vȈ, XF\Pub\Controller\Thread, Index, valid, thread_id=2717, 1714286291, , 0, vȈ
Run Time: 0.000160
WHERE (`xf_session_activity`.`user_id` = 2287) AND (`xf_session_activity`.`unique_key` = '2287')
Run Time: 0.000196
WHERE (`xf_thread_reply_ban`.`thread_id` = 2717) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000227
Run Time: 0.000247
bytes_sent | 12304 |
bytes_received | 273673 |
packets_sent | 124 |
packets_received | 1072 |
protocol_overhead_in | 4288 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 200872 |
packets_sent_command | 61 |
packets_received_change_user | 92 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 74 |
rows_buffered_from_client_ps | 74 |
rows_skipped_ps | 74 |
proto_binary_fetched_bit | 211 |
proto_binary_fetched_short | 125 |
proto_binary_fetched_int24 | 49 |
proto_binary_fetched_bigint | 352 |
proto_binary_fetched_decimal | 26 |
proto_binary_fetched_json | 397 |
proto_binary_fetched_blob | 144 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 199599 |
