Run Time: 0.000713
Run Time: 0.000207
WHERE (`xf_thread`.`thread_id` = '43809')
Run Time: 0.000743
WHERE (`xf_post`.`thread_id` = 43809) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002072
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 14 | Using where; Using filesort |
Params: 43809
Run Time: 0.000091
Params: 0, t3u
Run Time: 0.000151
Params: t3u, XF\Pub\Controller\Thread, Index, valid, thread_id=43809, 1714238285, , 0, t3u
Run Time: 0.000148
WHERE (`xf_session_activity`.`user_id` = 47410) AND (`xf_session_activity`.`unique_key` = '47410')
Run Time: 0.000197
WHERE (`xf_thread_reply_ban`.`thread_id` = 43809) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000220
Run Time: 0.000221
bytes_sent | 9840 |
bytes_received | 303466 |
packets_sent | 112 |
packets_received | 879 |
protocol_overhead_in | 3516 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 248687 |
packets_sent_command | 55 |
packets_received_change_user | 91 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 75 |
rows_buffered_from_client_ps | 75 |
rows_skipped_ps | 75 |
proto_binary_fetched_bit | 178 |
proto_binary_fetched_short | 262 |
proto_binary_fetched_int24 | 105 |
proto_binary_fetched_bigint | 681 |
proto_binary_fetched_json | 503 |
proto_binary_fetched_blob | 262 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 247047 |
