Run Time: 0.000440
Run Time: 0.000213
WHERE (`xf_thread`.`thread_id` = '10581')
Run Time: 0.001073
WHERE (`xf_post`.`thread_id` = 10581) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003857
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 16 | Using where; Using filesort |
Params: 10581
Run Time: 0.000113
Params: 0, ukZ
Run Time: 0.000188
Params: ukZ, XF\Pub\Controller\Thread, Index, valid, thread_id=10581, 1714327012, , 0, ukZ
Run Time: 0.000192
WHERE (`xf_session_activity`.`user_id` = 11894) AND (`xf_session_activity`.`unique_key` = '11894')
Run Time: 0.000161
WHERE (`xf_thread_reply_ban`.`thread_id` = 10581) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000196
Run Time: 0.000207
bytes_sent | 9840 |
bytes_received | 315681 |
packets_sent | 112 |
packets_received | 881 |
protocol_overhead_in | 3524 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 260902 |
packets_sent_command | 55 |
packets_received_change_user | 93 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 77 |
rows_buffered_from_client_ps | 77 |
rows_skipped_ps | 77 |
proto_binary_fetched_bit | 212 |
proto_binary_fetched_short | 291 |
proto_binary_fetched_int24 | 119 |
proto_binary_fetched_bigint | 764 |
proto_binary_fetched_json | 543 |
proto_binary_fetched_blob | 292 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 259158 |
