Remote control for D3200- wired or wireless?
Happy.snapper
I would like to be able to remotely trigger the camera shutter. I have found that there are wireless remotes and wired remotes. Does any one have any experience with these, and can anyone recommend which to get? is it important to get a branded Nikon one or do cheaper ones work just as well?
MartinCornwall
I have both and use both most of the time. Non branded ones are fine and are cheap so you can get both. I have a Pixel RW221 wireless (£21 Amazon) that I mainly use for light painting and a cheap £4 wired remote for other night photography.
RocketCowboy
Howdy and welcome to Nikonites!
Like others have said, I have both and use both fairly regularly. I started with the IR wireless remote and later started using the built in 802.11 wireless with the D5300 and the smartphone app (WMU). I've subsequently picked up a wired remote and use it too.
I prefer the wired remote over the IR remotes, just due to general line-of-sight kind of issues with IR. I use the 802.11 wireless app more frequently, so I can see the image composition before hitting the shutter release.
Hope that helps.
Happy.snapper
Yes I am sure you're right - I'll get one of each!
I want to trigger it from behind so probably the wired might work best? I am totally ignorant of these things, but assume that wireless works best when you are in front of the lens?
Happy.snapper
Hi, I've just had a look at that and it does look good. I shouldn't have too much trouble with channels/interference, as I want it for photographing the birds on my bird table at home without spooking them.
mikew_RIP
I bought two as i wanted to fire two cameras at the same time from one trigger.
Happy.snapper
