Run Time: 0.000499
Run Time: 0.000199
WHERE (`xf_thread`.`thread_id` = '42942')
Run Time: 0.000568
WHERE (`xf_post`.`thread_id` = 42942) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002192
Params: 42942
Run Time: 0.000077
Params: 0, uĸ
Run Time: 0.000123
Params: uĸ, XF\Pub\Controller\Thread, Index, valid, thread_id=42942, 1715333768, , 0, uĸ
Run Time: 0.000113
WHERE (`xf_session_activity`.`user_id` = 37465) AND (`xf_session_activity`.`unique_key` = '37465')
Run Time: 0.000144
WHERE (`xf_thread_reply_ban`.`thread_id` = 42942) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000197
Run Time: 0.000197
bytes_sent | 9840 |
bytes_received | 249405 |
packets_sent | 112 |
packets_received | 870 |
protocol_overhead_in | 3480 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 194626 |
packets_sent_command | 55 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 66 |
proto_binary_fetched_bit | 78 |
proto_binary_fetched_short | 105 |
proto_binary_fetched_bigint | 281 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 193539 |
