Run Time: 0.000721
Run Time: 0.000211
WHERE (`xf_thread`.`thread_id` = '40401')
Run Time: 0.000788
WHERE (`xf_post`.`thread_id` = 40401) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003135
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 13 | Using where; Using filesort |
Params: 40401
Run Time: 0.000098
Params: 0, t%>
Run Time: 0.000193
Params: t%>, XF\Pub\Controller\Thread, Index, valid, thread_id=40401, 1716333570, , 0, t%>
Run Time: 0.000154
WHERE (`xf_session_activity`.`user_id` = 37491) AND (`xf_session_activity`.`unique_key` = '37491')
Run Time: 0.000211
WHERE (`xf_thread_reply_ban`.`thread_id` = 40401) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000248
Run Time: 0.000234
bytes_sent | 9840 |
bytes_received | 295641 |
packets_sent | 112 |
packets_received | 878 |
protocol_overhead_in | 3512 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 240862 |
packets_sent_command | 55 |
packets_received_change_user | 90 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 74 |
rows_buffered_from_client_ps | 74 |
rows_skipped_ps | 74 |
proto_binary_fetched_bit | 174 |
proto_binary_fetched_short | 241 |
proto_binary_fetched_int24 | 98 |
proto_binary_fetched_bigint | 633 |
proto_binary_fetched_json | 483 |
proto_binary_fetched_blob | 247 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 239297 |
