Run Time: 0.000687
Run Time: 0.000252
WHERE (`xf_thread`.`thread_id` = '43461')
Run Time: 0.000790
WHERE (`xf_post`.`thread_id` = 43461) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002323
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (709179))
Run Time: 0.001379
Params: 43461
Run Time: 0.000100
Params: 0,
Run Time: 0.000142
WHERE (`xf_session_activity`.`user_id` = 46943) AND (`xf_session_activity`.`unique_key` = '46943')
Run Time: 0.000211
Run Time: 0.000286
bytes_sent | 11406 |
bytes_received | 325706 |
packets_sent | 106 |
packets_received | 1023 |
protocol_overhead_in | 4092 |
protocol_overhead_out | 424 |
bytes_received_prepare_response_packet | 69509 |
bytes_received_change_user_packet | 255295 |
packets_sent_command | 52 |
packets_received_prepare_response | 851 |
result_set_queries | 16 |
non_result_set_queries | 3 |
ps_buffered_sets | 16 |
rows_skipped_ps | 81 |
proto_binary_fetched_bit | 249 |
proto_binary_fetched_short | 279 |
proto_binary_fetched_bigint | 734 |
proto_binary_fetched_decimal | 24 |
proto_binary_fetched_json | 571 |
proto_binary_fetched_blob | 278 |
com_stmt_prepare | 17 |
com_stmt_execute | 17 |
com_stmt_close | 16 |
bytes_received_real_data_ps | 253517 |
