Run Time: 0.000691
Run Time: 0.000195
WHERE (`xf_thread`.`thread_id` = '45913')
Run Time: 0.000784
WHERE (`xf_post`.`thread_id` = 45913) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003373
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (778697, 778703, 778781, 778814, 778835))
Run Time: 0.001185
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 8 | Using index condition; Using filesort |
Params: 45913
Run Time: 0.000106
Params: 0,
Run Time: 0.000232
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=45913, 1716248558, , 0,
Run Time: 0.000155
WHERE (`xf_thread_reply_ban`.`thread_id` = 45913) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000185
Run Time: 0.000173
bytes_sent | 11889 |
bytes_received | 360483 |
packets_sent | 112 |
packets_received | 1042 |
protocol_overhead_in | 4168 |
protocol_overhead_out | 448 |
bytes_received_prepare_response_packet | 69392 |
bytes_received_change_user_packet | 290153 |
packets_sent_command | 55 |
packets_received_prepare_response | 856 |
packets_received_change_user | 108 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 92 |
rows_buffered_from_client_ps | 92 |
rows_skipped_ps | 92 |
proto_binary_fetched_bit | 579 |
proto_binary_fetched_short | 389 |
proto_binary_fetched_bigint | 1083 |
proto_binary_fetched_decimal | 31 |
proto_binary_fetched_json | 809 |
proto_binary_fetched_blob | 357 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 287822 |
