Run Time: 0.000471
Run Time: 0.000190
WHERE (`xf_thread`.`thread_id` = '9959')
Run Time: 0.000990
WHERE (`xf_post`.`thread_id` = 9959) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004684
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (100284, 100370, 100576, 100978, 101226, 101636, 102117, 102336))
Run Time: 0.001165
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 16 | Using index condition; Using filesort |
Params: 9959
Run Time: 0.000084
Params: 0,
Run Time: 0.000132
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=9959, 1714253532, , 0,
Run Time: 0.000131
WHERE (`xf_session_activity`.`user_id` = 12215) AND (`xf_session_activity`.`unique_key` = '12215')
Run Time: 0.000126
WHERE (`xf_thread_reply_ban`.`thread_id` = 9959) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000181
Run Time: 0.000185
bytes_sent | 12408 |
bytes_received | 358587 |
packets_sent | 124 |
packets_received | 1100 |
protocol_overhead_in | 4400 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 285786 |
packets_sent_command | 61 |
packets_received_change_user | 120 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 102 |
rows_buffered_from_client_ps | 102 |
rows_skipped_ps | 102 |
proto_binary_fetched_bit | 1218 |
proto_binary_fetched_short | 391 |
proto_binary_fetched_bigint | 1164 |
proto_binary_fetched_decimal | 40 |
proto_binary_fetched_json | 746 |
proto_binary_fetched_blob | 356 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 283382 |
