Run Time: 0.000598
Run Time: 0.000216
WHERE (`xf_thread`.`thread_id` = '1803')
Run Time: 0.000834
WHERE (`xf_post`.`thread_id` = 1803) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004063
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 27 | Using index condition; Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (11063, 11454, 11555, 11645))
Run Time: 0.000879
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 4 | Using index condition; Using filesort |
Params: 1803
Run Time: 0.000088
Params: 0,
Run Time: 0.000155
WHERE (`xf_session_activity`.`user_id` = 1556) AND (`xf_session_activity`.`unique_key` = '1556')
Run Time: 0.000202
WHERE (`xf_thread_reply_ban`.`thread_id` = 1803) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000207
Run Time: 0.000221
bytes_sent | 11931 |
bytes_received | 348545 |
packets_sent | 118 |
packets_received | 1076 |
protocol_overhead_in | 4304 |
protocol_overhead_out | 472 |
bytes_received_rset_header_packet | 369 |
bytes_received_rset_row_packet | 123 |
bytes_received_prepare_response_packet | 71491 |
bytes_received_change_user_packet | 276064 |
packets_sent_command | 58 |
packets_received_rset_header | 41 |
packets_received_rset_row | 21 |
packets_received_prepare_response | 885 |
packets_received_change_user | 108 |
result_set_queries | 18 |
non_result_set_queries | 3 |
ps_buffered_sets | 18 |
ps_prepared_once_executed | 18 |
rows_fetched_from_server_ps | 90 |
rows_buffered_from_client_ps | 90 |
rows_skipped_ps | 90 |
proto_binary_fetched_bit | 498 |
proto_binary_fetched_short | 367 |
proto_binary_fetched_bigint | 996 |
proto_binary_fetched_decimal | 28 |
proto_binary_fetched_json | 686 |
proto_binary_fetched_blob | 356 |
com_stmt_prepare | 19 |
com_stmt_execute | 19 |
com_stmt_close | 18 |
bytes_received_real_data_ps | 273924 |
