Run Time: 0.000622
Run Time: 0.000205
WHERE (`xf_thread`.`thread_id` = '1653')
Run Time: 0.001132
WHERE (`xf_post`.`thread_id` = 1653) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001853
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 7 | Using where; Using filesort |
Params: 1653
Run Time: 0.000086
Params: 0, I
Run Time: 0.000150
WHERE (`xf_session_activity`.`user_id` = 920) AND (`xf_session_activity`.`unique_key` = '920')
Run Time: 0.000204
WHERE (`xf_thread_reply_ban`.`thread_id` = 1653) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000219
Run Time: 0.000218
bytes_sent | 9423 |
bytes_received | 258557 |
packets_sent | 106 |
packets_received | 860 |
protocol_overhead_in | 3440 |
protocol_overhead_out | 424 |
bytes_received_change_user_packet | 204098 |
packets_sent_command | 52 |
packets_received_change_user | 84 |
result_set_queries | 16 |
non_result_set_queries | 3 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 68 |
rows_buffered_from_client_ps | 68 |
rows_skipped_ps | 68 |
proto_binary_fetched_bit | 104 |
proto_binary_fetched_short | 138 |
proto_binary_fetched_int24 | 56 |
proto_binary_fetched_bigint | 368 |
proto_binary_fetched_json | 363 |
proto_binary_fetched_blob | 157 |
com_stmt_prepare | 17 |
com_stmt_execute | 17 |
com_stmt_close | 16 |
bytes_received_real_data_ps | 202901 |
