Run Time: 0.000508
Run Time: 0.000183
WHERE (`xf_thread`.`thread_id` = '40045')
Run Time: 0.000689
WHERE (`xf_post`.`thread_id` = 40045) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002249
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (636359, 636369, 642587, 642588, 642589, 646461))
Run Time: 0.001968
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 13 | Using index condition; Using filesort |
Params: 40045
Run Time: 0.000087
Params: 0,
Run Time: 0.000171
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=40045, 1715121555, , 0,
Run Time: 0.000159
WHERE (`xf_session_activity`.`user_id` = 10447) AND (`xf_session_activity`.`unique_key` = '10447')
Run Time: 0.000198
WHERE (`xf_thread_reply_ban`.`thread_id` = 40045) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000258
Run Time: 0.000252
bytes_sent | 12384 |
bytes_received | 355799 |
packets_sent | 124 |
packets_received | 1097 |
protocol_overhead_in | 4388 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 282998 |
packets_sent_command | 61 |
packets_received_change_user | 117 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 99 |
rows_buffered_from_client_ps | 99 |
rows_skipped_ps | 99 |
proto_binary_fetched_bit | 1034 |
proto_binary_fetched_short | 387 |
proto_binary_fetched_bigint | 1122 |
proto_binary_fetched_decimal | 37 |
proto_binary_fetched_json | 731 |
proto_binary_fetched_blob | 358 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 280659 |
