Run Time: 0.000573
Run Time: 0.000245
WHERE (`xf_thread`.`thread_id` = '19328')
Run Time: 0.001055
WHERE (`xf_post`.`thread_id` = 19328) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002066
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (240935))
Run Time: 0.000775
Params: 19328
Run Time: 0.000093
Params: 0, ;=w
Run Time: 0.000159
Params: ;=w, XF\Pub\Controller\Thread, Index, valid, thread_id=19328, 1714328551, , 0, ;=w
Run Time: 0.000150
WHERE (`xf_session_activity`.`user_id` = 9701) AND (`xf_session_activity`.`unique_key` = '9701')
Run Time: 0.000242
WHERE (`xf_thread_reply_ban`.`thread_id` = 19328) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000208
Run Time: 0.000238
bytes_sent | 12300 |
bytes_received | 269921 |
packets_sent | 124 |
packets_received | 1070 |
protocol_overhead_in | 4280 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 197120 |
packets_sent_command | 61 |
packets_received_change_user | 90 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 72 |
rows_buffered_from_client_ps | 72 |
rows_skipped_ps | 72 |
proto_binary_fetched_bit | 129 |
proto_binary_fetched_short | 107 |
proto_binary_fetched_bigint | 296 |
proto_binary_fetched_json | 380 |
proto_binary_fetched_blob | 128 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 195908 |
