Run Time: 0.000465
Run Time: 0.000193
WHERE (`xf_thread`.`thread_id` = '36771')
Run Time: 0.000544
WHERE (`xf_post`.`thread_id` = 36771) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002954
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 19 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (566398, 566424, 566430, 566444, 566473, 566650, 566674))
Run Time: 0.002047
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 14 | Using index condition; Using filesort |
Params: 36771
Run Time: 0.000090
Params: 0,
Run Time: 0.000142
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=36771, 1714661783, , 0,
Run Time: 0.000121
WHERE (`xf_session_activity`.`user_id` = 13196) AND (`xf_session_activity`.`unique_key` = '13196')
Run Time: 0.000171
WHERE (`xf_thread_reply_ban`.`thread_id` = 36771) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000195
Run Time: 0.000191
bytes_sent | 12400 |
bytes_received | 358931 |
packets_sent | 124 |
packets_received | 1097 |
protocol_overhead_in | 4388 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 286130 |
packets_sent_command | 61 |
packets_received_change_user | 117 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 99 |
rows_buffered_from_client_ps | 99 |
rows_skipped_ps | 99 |
proto_binary_fetched_bit | 1082 |
proto_binary_fetched_short | 370 |
proto_binary_fetched_int24 | 140 |
proto_binary_fetched_bigint | 1092 |
proto_binary_fetched_decimal | 38 |
proto_binary_fetched_json | 717 |
proto_binary_fetched_blob | 344 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 283779 |
