Run Time: 0.000505
Run Time: 0.000204
WHERE (`xf_thread`.`thread_id` = '35119')
Run Time: 0.000989
WHERE (`xf_post`.`thread_id` = 35119) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002556
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 6 | Using where; Using filesort |
Params: 35119
Run Time: 0.000091
Params: 0, ڨ
Run Time: 0.000182
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: ڨ, XF\Pub\Controller\Thread, Index, valid, thread_id=35119, 1714684716, , 0, ڨ
Run Time: 0.000101
WHERE (`xf_session_activity`.`user_id` = 22994) AND (`xf_session_activity`.`unique_key` = '22994')
Run Time: 0.000207
WHERE (`xf_thread_reply_ban`.`thread_id` = 35119) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000232
Run Time: 0.000222
bytes_sent | 9853 |
bytes_received | 253474 |
packets_sent | 112 |
packets_received | 870 |
protocol_overhead_in | 3480 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 198736 |
packets_sent_command | 55 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 66 |
proto_binary_fetched_bit | 91 |
proto_binary_fetched_short | 121 |
proto_binary_fetched_int24 | 49 |
proto_binary_fetched_bigint | 324 |
proto_binary_fetched_json | 343 |
proto_binary_fetched_blob | 142 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 197600 |
