Run Time: 0.000566
Run Time: 0.000229
WHERE (`xf_thread`.`thread_id` = '4089')
Run Time: 0.001097
WHERE (`xf_post`.`thread_id` = 4089) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002704
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 10 | Using where; Using filesort |
Params: 4089
Run Time: 0.000095
Params: 0, ܚ)
Run Time: 0.000178
Params: ܚ), XF\Pub\Controller\Thread, Index, valid, thread_id=4089, 1714545168, , 0, ܚ)
Run Time: 0.000170
WHERE (`xf_session_activity`.`user_id` = 7507) AND (`xf_session_activity`.`unique_key` = '7507')
Run Time: 0.000197
WHERE (`xf_thread_reply_ban`.`thread_id` = 4089) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000230
Run Time: 0.000235
bytes_sent | 9828 |
bytes_received | 280608 |
packets_sent | 112 |
packets_received | 875 |
protocol_overhead_in | 3500 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 225829 |
packets_sent_command | 55 |
packets_received_change_user | 87 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 71 |
rows_buffered_from_client_ps | 71 |
rows_skipped_ps | 71 |
proto_binary_fetched_bit | 140 |
proto_binary_fetched_short | 189 |
proto_binary_fetched_int24 | 77 |
proto_binary_fetched_bigint | 500 |
proto_binary_fetched_json | 423 |
proto_binary_fetched_blob | 202 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 224433 |
