Run Time: 0.000480
Run Time: 0.000194
WHERE (`xf_thread`.`thread_id` = '24699')
Run Time: 0.001273
WHERE (`xf_post`.`thread_id` = 24699) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002248
Params: 24699
Run Time: 0.000096
Params: 0, D
Run Time: 0.000166
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: D, XF\Pub\Controller\Thread, Index, valid, thread_id=24699, 1715032108, , 0, D
Run Time: 0.000120
WHERE (`xf_session_activity`.`user_id` = 29906) AND (`xf_session_activity`.`unique_key` = '29906')
Run Time: 0.000194
WHERE (`xf_thread_reply_ban`.`thread_id` = 24699) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000226
Run Time: 0.000218
bytes_sent | 9847 |
bytes_received | 252587 |
packets_sent | 112 |
packets_received | 870 |
protocol_overhead_in | 3480 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 197849 |
packets_sent_command | 55 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 66 |
proto_binary_fetched_bit | 77 |
proto_binary_fetched_short | 105 |
proto_binary_fetched_bigint | 282 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 196750 |
