Run Time: 0.000735
Run Time: 0.000189
WHERE (`xf_thread`.`thread_id` = '39248')
Run Time: 0.001011
WHERE (`xf_post`.`thread_id` = 39248) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003097
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 9 | Using where; Using filesort |
Params: 39248
Run Time: 0.000121
Params: 0, $
Run Time: 0.000222
Params: $, XF\Pub\Controller\Thread, Index, valid, thread_id=39248, 1714242447, , 0, $
Run Time: 0.000181
WHERE (`xf_session_activity`.`user_id` = 43585) AND (`xf_session_activity`.`unique_key` = '43585')
Run Time: 0.000175
WHERE (`xf_thread_reply_ban`.`thread_id` = 39248) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000280
Run Time: 0.000235
bytes_sent | 9840 |
bytes_received | 276072 |
packets_sent | 112 |
packets_received | 874 |
protocol_overhead_in | 3496 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 221293 |
packets_sent_command | 55 |
packets_received_change_user | 86 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 70 |
rows_buffered_from_client_ps | 70 |
rows_skipped_ps | 70 |
proto_binary_fetched_bit | 123 |
proto_binary_fetched_short | 174 |
proto_binary_fetched_int24 | 70 |
proto_binary_fetched_bigint | 458 |
proto_binary_fetched_json | 403 |
proto_binary_fetched_blob | 188 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 219961 |
