Run Time: 0.000513
Run Time: 0.000176
WHERE (`xf_thread`.`thread_id` = '44169')
Run Time: 0.000564
WHERE (`xf_post`.`thread_id` = 44169) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001866
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 7 | Using where; Using filesort |
Params: 44169
Run Time: 0.000126
Params: 0, hm
Run Time: 0.000156
WHERE (`xf_session_activity`.`user_id` = 45742) AND (`xf_session_activity`.`unique_key` = '45742')
Run Time: 0.000180
WHERE (`xf_thread_reply_ban`.`thread_id` = 44169) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000260
Run Time: 0.000222
bytes_sent | 9438 |
bytes_received | 262623 |
packets_sent | 106 |
packets_received | 860 |
protocol_overhead_in | 3440 |
protocol_overhead_out | 424 |
bytes_received_change_user_packet | 208164 |
packets_sent_command | 52 |
packets_received_change_user | 84 |
result_set_queries | 16 |
non_result_set_queries | 3 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 68 |
rows_buffered_from_client_ps | 68 |
rows_skipped_ps | 68 |
proto_binary_fetched_bit | 102 |
proto_binary_fetched_short | 139 |
proto_binary_fetched_int24 | 56 |
proto_binary_fetched_bigint | 369 |
proto_binary_fetched_json | 363 |
proto_binary_fetched_blob | 157 |
com_stmt_prepare | 17 |
com_stmt_execute | 17 |
com_stmt_close | 16 |
bytes_received_real_data_ps | 206945 |
