Run Time: 0.000694
Run Time: 0.000201
WHERE (`xf_thread`.`thread_id` = '23355')
Run Time: 0.000784
WHERE (`xf_post`.`thread_id` = 23355) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002606
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 12 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (316533, 316546, 316577, 316619))
Run Time: 0.001555
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 4 | Using index condition; Using filesort |
Params: 23355
Run Time: 0.000099
Params: 0, v~
Run Time: 0.000179
Params: v~, XF\Pub\Controller\Thread, Index, valid, thread_id=23355, 1716034442, , 0, v~
Run Time: 0.000147
WHERE (`xf_session_activity`.`user_id` = 13344) AND (`xf_session_activity`.`unique_key` = '13344')
Run Time: 0.000195
WHERE (`xf_thread_reply_ban`.`thread_id` = 23355) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000252
Run Time: 0.000211
bytes_sent | 12352 |
bytes_received | 310379 |
packets_sent | 124 |
packets_received | 1080 |
protocol_overhead_in | 4320 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 237578 |
packets_sent_command | 61 |
packets_received_change_user | 100 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 82 |
rows_buffered_from_client_ps | 82 |
rows_skipped_ps | 82 |
proto_binary_fetched_bit | 398 |
proto_binary_fetched_short | 231 |
proto_binary_fetched_int24 | 91 |
proto_binary_fetched_bigint | 647 |
proto_binary_fetched_decimal | 28 |
proto_binary_fetched_json | 527 |
proto_binary_fetched_blob | 236 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 235889 |
