Run Time: 0.000642
Run Time: 0.000200
WHERE (`xf_thread`.`thread_id` = '3617')
Run Time: 0.000770
WHERE (`xf_post`.`thread_id` = 3617) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002959
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 13 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (32801))
Run Time: 0.001043
Params: 3617
Run Time: 0.000088
Params: 0, ݻy
Run Time: 0.000188
Params: ݻy, XF\Pub\Controller\Thread, Index, valid, thread_id=3617, 1714665043, , 0, ݻy
Run Time: 0.000152
WHERE (`xf_session_activity`.`user_id` = 7891) AND (`xf_session_activity`.`unique_key` = '7891')
Run Time: 0.000203
WHERE (`xf_thread_reply_ban`.`thread_id` = 3617) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000208
Run Time: 0.000211
bytes_sent | 12290 |
bytes_received | 309958 |
packets_sent | 124 |
packets_received | 1078 |
protocol_overhead_in | 4312 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 237157 |
packets_sent_command | 61 |
packets_received_change_user | 98 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_skipped_ps | 80 |
proto_binary_fetched_bit | 235 |
proto_binary_fetched_short | 242 |
proto_binary_fetched_int24 | 98 |
proto_binary_fetched_bigint | 646 |
proto_binary_fetched_json | 533 |
proto_binary_fetched_blob | 248 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 235492 |
