Run Time: 0.000486
Run Time: 0.000225
WHERE (`xf_thread`.`thread_id` = '11453')
Run Time: 0.001003
WHERE (`xf_post`.`thread_id` = 11453) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002208
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 7 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (119615, 119618))
Run Time: 0.001419
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 2 | Using index condition; Using filesort |
Params: 11453
Run Time: 0.000151
Params: 0, )W
Run Time: 0.000158
Params: )W, XF\Pub\Controller\Thread, Index, valid, thread_id=11453, 1715911175, , 0, )W
Run Time: 0.000150
WHERE (`xf_session_activity`.`user_id` = 13104) AND (`xf_session_activity`.`unique_key` = '13104')
Run Time: 0.000158
WHERE (`xf_thread_reply_ban`.`thread_id` = 11453) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000282
Run Time: 0.000203
bytes_sent | 12320 |
bytes_received | 283125 |
packets_sent | 124 |
packets_received | 1073 |
protocol_overhead_in | 4292 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 210324 |
packets_sent_command | 61 |
packets_received_change_user | 93 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 75 |
rows_buffered_from_client_ps | 75 |
rows_skipped_ps | 75 |
proto_binary_fetched_bit | 222 |
proto_binary_fetched_short | 142 |
proto_binary_fetched_int24 | 56 |
proto_binary_fetched_bigint | 397 |
proto_binary_fetched_decimal | 26 |
proto_binary_fetched_json | 417 |
proto_binary_fetched_blob | 159 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 208980 |
