Run Time: 0.000479
Run Time: 0.000181
WHERE (`xf_thread`.`thread_id` = '7791')
Run Time: 0.000593
WHERE (`xf_post`.`thread_id` = 7791) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001564
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 10 | Using where; Using filesort |
Params: 7791
Run Time: 0.000089
Params: 0, t q
Run Time: 0.000163
WHERE (`xf_session_activity`.`user_id` = 9521) AND (`xf_session_activity`.`unique_key` = '9521')
Run Time: 0.000165
WHERE (`xf_thread_reply_ban`.`thread_id` = 7791) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000185
Run Time: 0.000172
bytes_sent | 9427 |
bytes_received | 277947 |
packets_sent | 106 |
packets_received | 863 |
protocol_overhead_in | 3452 |
protocol_overhead_out | 424 |
bytes_received_change_user_packet | 223488 |
packets_sent_command | 52 |
packets_received_change_user | 87 |
result_set_queries | 16 |
non_result_set_queries | 3 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 71 |
rows_buffered_from_client_ps | 71 |
rows_skipped_ps | 71 |
proto_binary_fetched_bit | 140 |
proto_binary_fetched_short | 189 |
proto_binary_fetched_int24 | 77 |
proto_binary_fetched_bigint | 500 |
proto_binary_fetched_json | 423 |
proto_binary_fetched_blob | 202 |
com_stmt_prepare | 17 |
com_stmt_execute | 17 |
com_stmt_close | 16 |
bytes_received_real_data_ps | 222096 |
