Run Time: 0.000604
Run Time: 0.000208
WHERE (`xf_thread`.`thread_id` = '26610')
Run Time: 0.000844
WHERE (`xf_post`.`thread_id` = 26610) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004058
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 18 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (374709, 374872, 374952, 375107))
Run Time: 0.001665
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 6 | Using index condition; Using filesort |
Params: 26610
Run Time: 0.000093
Params: 0, ;d*
Run Time: 0.000139
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: ;d*, XF\Pub\Controller\Thread, Index, valid, thread_id=26610, 1715017372, , 0, ;d*
Run Time: 0.000090
WHERE (`xf_session_activity`.`user_id` = 27576) AND (`xf_session_activity`.`unique_key` = '27576')
Run Time: 0.000151
WHERE (`xf_thread_reply_ban`.`thread_id` = 26610) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000187
Run Time: 0.000183
bytes_sent | 12365 |
bytes_received | 344938 |
packets_sent | 124 |
packets_received | 1087 |
protocol_overhead_in | 4348 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 272178 |
packets_sent_command | 61 |
packets_received_change_user | 107 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 89 |
rows_buffered_from_client_ps | 89 |
rows_skipped_ps | 89 |
proto_binary_fetched_bit | 592 |
proto_binary_fetched_short | 337 |
proto_binary_fetched_int24 | 133 |
proto_binary_fetched_bigint | 935 |
proto_binary_fetched_decimal | 30 |
proto_binary_fetched_json | 657 |
proto_binary_fetched_blob | 327 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 270084 |
