Run Time: 0.000497
Run Time: 0.000196
WHERE (`xf_thread`.`thread_id` = '38089')
Run Time: 0.001123
WHERE (`xf_post`.`thread_id` = 38089) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003054
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 13 | Using where; Using filesort |
Params: 38089
Run Time: 0.000086
Params: 0,
Run Time: 0.000137
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=38089, 1714311613, , 0,
Run Time: 0.000141
WHERE (`xf_thread_reply_ban`.`thread_id` = 38089) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000194
Run Time: 0.000198
bytes_sent | 9348 |
bytes_received | 299557 |
packets_sent | 100 |
packets_received | 829 |
protocol_overhead_in | 3316 |
protocol_overhead_out | 400 |
bytes_received_rset_header_packet | 306 |
bytes_received_rset_row_packet | 155 |
bytes_received_prepare_response_packet | 51458 |
bytes_received_change_user_packet | 247208 |
packets_sent_command | 49 |
packets_received_rset_header | 34 |
packets_received_rset_row | 18 |
packets_received_prepare_response | 672 |
packets_received_change_user | 87 |
result_set_queries | 14 |
ps_buffered_sets | 14 |
ps_prepared_once_executed | 15 |
rows_fetched_from_server_ps | 73 |
rows_buffered_from_client_ps | 73 |
rows_skipped_ps | 73 |
proto_binary_fetched_bit | 105 |
proto_binary_fetched_short | 248 |
proto_binary_fetched_int24 | 98 |
proto_binary_fetched_bigint | 646 |
proto_binary_fetched_decimal | 18 |
proto_binary_fetched_json | 523 |
proto_binary_fetched_blob | 247 |
com_stmt_prepare | 16 |
com_stmt_execute | 16 |
com_stmt_close | 15 |
bytes_received_real_data_ps | 245590 |
