Run Time: 0.000373
Run Time: 0.000143
WHERE (`xf_thread`.`thread_id` = '23642')
Run Time: 0.000500
WHERE (`xf_post`.`thread_id` = 23642) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002820
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 12 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (321778, 334747, 342904, 342907, 345234))
Run Time: 0.002820
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 35 | Using index condition; Using filesort |
Params: 23642
Run Time: 0.000075
Params: 0, v҅
Run Time: 0.000141
Params: v҅, XF\Pub\Controller\Thread, Index, valid, thread_id=23642, 1716040073, , 0, v҅
Run Time: 0.000101
WHERE (`xf_session_activity`.`user_id` = 16090) AND (`xf_session_activity`.`unique_key` = '16090')
Run Time: 0.000176
WHERE (`xf_thread_reply_ban`.`thread_id` = 23642) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000217
Run Time: 0.000211
bytes_sent | 12368 |
bytes_received | 312787 |
packets_sent | 124 |
packets_received | 1111 |
protocol_overhead_in | 4444 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 239986 |
packets_sent_command | 61 |
packets_received_change_user | 131 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 113 |
rows_buffered_from_client_ps | 113 |
rows_skipped_ps | 113 |
proto_binary_fetched_bit | 2259 |
proto_binary_fetched_short | 294 |
proto_binary_fetched_int24 | 91 |
proto_binary_fetched_bigint | 1078 |
proto_binary_fetched_decimal | 59 |
proto_binary_fetched_json | 682 |
proto_binary_fetched_blob | 237 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 237665 |
