Run Time: 0.000540
Run Time: 0.000213
WHERE (`xf_thread`.`thread_id` = '38459')
Run Time: 0.000743
WHERE (`xf_post`.`thread_id` = 38459) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004038
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (599191, 600456, 600931, 601389, 601390, 601391, 601628, 602265, 602413, 603492, 603529, 603553, 603554, 603555, 603556, 604835, 604843))
Run Time: 0.004660
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 26 | Using index condition; Using filesort |
Params: 38459
Run Time: 0.000101
Params: 0,
Run Time: 0.000186
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=38459, 1714327316, , 0,
Run Time: 0.000221
WHERE (`xf_session_activity`.`user_id` = 11881) AND (`xf_session_activity`.`unique_key` = '11881')
Run Time: 0.000201
WHERE (`xf_thread_reply_ban`.`thread_id` = 38459) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000243
Run Time: 0.000218
bytes_sent | 12560 |
bytes_received | 356887 |
packets_sent | 124 |
packets_received | 1110 |
protocol_overhead_in | 4440 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 284086 |
packets_sent_command | 61 |
packets_received_change_user | 130 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 112 |
rows_buffered_from_client_ps | 112 |
rows_skipped_ps | 112 |
proto_binary_fetched_bit | 1802 |
proto_binary_fetched_short | 413 |
proto_binary_fetched_bigint | 1305 |
proto_binary_fetched_decimal | 50 |
proto_binary_fetched_json | 796 |
proto_binary_fetched_blob | 369 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 281457 |
