Run Time: 0.000645
Run Time: 0.000187
WHERE (`xf_thread`.`thread_id` = '42781')
Run Time: 0.001052
WHERE (`xf_post`.`thread_id` = 42781) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002044
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 10 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (691754, 691755, 691756, 691759, 691998, 692138, 695436, 695569, 695570, 696183))
Run Time: 0.001343
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 11 | Using index condition; Using filesort |
Params: 42781
Run Time: 0.000091
Params: 0, ٨T
Run Time: 0.000139
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: ٨T, XF\Pub\Controller\Thread, Index, valid, thread_id=42781, 1715969959, , 0, ٨T
Run Time: 0.000102
WHERE (`xf_session_activity`.`user_id` = 14174) AND (`xf_session_activity`.`unique_key` = '14174')
Run Time: 0.000152
WHERE (`xf_thread_reply_ban`.`thread_id` = 42781) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000182
Run Time: 0.000202
bytes_sent | 12461 |
bytes_received | 299798 |
packets_sent | 124 |
packets_received | 1084 |
protocol_overhead_in | 4336 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 227038 |
packets_sent_command | 61 |
packets_received_change_user | 104 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 86 |
rows_buffered_from_client_ps | 86 |
rows_skipped_ps | 86 |
proto_binary_fetched_bit | 791 |
proto_binary_fetched_short | 211 |
proto_binary_fetched_int24 | 77 |
proto_binary_fetched_bigint | 653 |
proto_binary_fetched_decimal | 35 |
proto_binary_fetched_json | 522 |
proto_binary_fetched_blob | 212 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 225316 |
