Run Time: 0.000463
Run Time: 0.000183
WHERE (`xf_thread`.`thread_id` = '20232')
Run Time: 0.000704
WHERE (`xf_post`.`thread_id` = 20232) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002858
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 20 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (260313, 260324, 260854, 261431))
Run Time: 0.001837
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 4 | Using index condition; Using filesort |
Params: 20232
Run Time: 0.000092
Params: 0,
Run Time: 0.000138
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=20232, 1714324166, , 0,
Run Time: 0.000123
WHERE (`xf_session_activity`.`user_id` = 15434) AND (`xf_session_activity`.`unique_key` = '15434')
Run Time: 0.000187
WHERE (`xf_thread_reply_ban`.`thread_id` = 20232) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000225
Run Time: 0.000230
bytes_sent | 12352 |
bytes_received | 350071 |
packets_sent | 124 |
packets_received | 1088 |
protocol_overhead_in | 4352 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 277270 |
packets_sent_command | 61 |
packets_received_change_user | 108 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 90 |
rows_buffered_from_client_ps | 90 |
rows_skipped_ps | 90 |
proto_binary_fetched_bit | 497 |
proto_binary_fetched_short | 367 |
proto_binary_fetched_bigint | 996 |
proto_binary_fetched_decimal | 28 |
proto_binary_fetched_json | 687 |
proto_binary_fetched_blob | 356 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 275105 |
