Run Time: 0.000374
Run Time: 0.000206
WHERE (`xf_thread`.`thread_id` = '21301')
Run Time: 0.001148
WHERE (`xf_post`.`thread_id` = 21301) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003728
Params: 21301
Run Time: 0.000093
Params: 0, :RO
Run Time: 0.000191
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: :RO, XF\Pub\Controller\Thread, Index, valid, thread_id=21301, 1714988119, , 0, :RO
Run Time: 0.000100
WHERE (`xf_session_activity`.`user_id` = 22866) AND (`xf_session_activity`.`unique_key` = '22866')
Run Time: 0.000176
WHERE (`xf_thread_reply_ban`.`thread_id` = 21301) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000203
Run Time: 0.000221
bytes_sent | 9853 |
bytes_received | 312726 |
packets_sent | 112 |
packets_received | 879 |
protocol_overhead_in | 3516 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 257988 |
packets_sent_command | 55 |
packets_received_change_user | 91 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 75 |
rows_buffered_from_client_ps | 75 |
rows_skipped_ps | 75 |
proto_binary_fetched_bit | 200 |
proto_binary_fetched_short | 274 |
proto_binary_fetched_bigint | 719 |
proto_binary_fetched_json | 523 |
proto_binary_fetched_blob | 277 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 256283 |
