Run Time: 0.000497
Run Time: 0.000197
WHERE (`xf_thread`.`thread_id` = '21598')
Run Time: 0.000892
WHERE (`xf_post`.`thread_id` = 21598) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002891
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 17 | Using where; Using filesort |
Params: 21598
Run Time: 0.000091
Params: 0, :RO
Run Time: 0.000156
Params: :RO, XF\Pub\Controller\Thread, Index, valid, thread_id=21598, 1715279125, , 0, :RO
Run Time: 0.000142
WHERE (`xf_session_activity`.`user_id` = 21543) AND (`xf_session_activity`.`unique_key` = '21543')
Run Time: 0.000171
WHERE (`xf_thread_reply_ban`.`thread_id` = 21598) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000217
Run Time: 0.000237
bytes_sent | 9840 |
bytes_received | 326570 |
packets_sent | 112 |
packets_received | 882 |
protocol_overhead_in | 3528 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 271791 |
packets_sent_command | 55 |
packets_received_change_user | 94 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 78 |
rows_buffered_from_client_ps | 78 |
rows_skipped_ps | 78 |
proto_binary_fetched_bit | 214 |
proto_binary_fetched_short | 310 |
proto_binary_fetched_int24 | 126 |
proto_binary_fetched_bigint | 816 |
proto_binary_fetched_json | 563 |
proto_binary_fetched_blob | 307 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 269950 |
