Run Time: 0.000425
Run Time: 0.000166
WHERE (`xf_thread`.`thread_id` = '20935')
Run Time: 0.000590
WHERE (`xf_post`.`thread_id` = 20935) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001882
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 6 | Using where; Using filesort |
Params: 20935
Run Time: 0.000067
Params: 0, ٶ-
Run Time: 0.000130
Params: ٶ-, XF\Pub\Controller\Thread, Index, valid, thread_id=20935, 1714740279, , 0, ٶ-
Run Time: 0.000120
WHERE (`xf_session_activity`.`user_id` = 22109) AND (`xf_session_activity`.`unique_key` = '22109')
Run Time: 0.000195
WHERE (`xf_thread_reply_ban`.`thread_id` = 20935) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000214
Run Time: 0.000241
bytes_sent | 9840 |
bytes_received | 256813 |
packets_sent | 112 |
packets_received | 871 |
protocol_overhead_in | 3484 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 202034 |
packets_sent_command | 55 |
packets_received_change_user | 83 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 67 |
rows_buffered_from_client_ps | 67 |
rows_skipped_ps | 67 |
proto_binary_fetched_bit | 92 |
proto_binary_fetched_short | 121 |
proto_binary_fetched_int24 | 49 |
proto_binary_fetched_bigint | 324 |
proto_binary_fetched_json | 343 |
proto_binary_fetched_blob | 142 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 200880 |
