Run Time: 0.000470
Run Time: 0.000175
WHERE (`xf_thread`.`thread_id` = '14535')
Run Time: 0.000538
WHERE (`xf_post`.`thread_id` = 14535) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.000805
Params: 14535
Run Time: 0.000090
Params: 0, ݻy
Run Time: 0.000123
Params: ݻy, XF\Pub\Controller\Thread, Index, valid, thread_id=14535, 1714276230, , 0, ݻy
Run Time: 0.000125
WHERE (`xf_session_activity`.`user_id` = 14824) AND (`xf_session_activity`.`unique_key` = '14824')
Run Time: 0.000171
WHERE (`xf_thread_reply_ban`.`thread_id` = 14535) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000206
Run Time: 0.000171
bytes_sent | 9840 |
bytes_received | 251360 |
packets_sent | 112 |
packets_received | 870 |
protocol_overhead_in | 3480 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 196581 |
packets_sent_command | 55 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 66 |
proto_binary_fetched_bit | 80 |
proto_binary_fetched_short | 104 |
proto_binary_fetched_bigint | 280 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 195478 |
