Run Time: 0.000363
Run Time: 0.000219
WHERE (`xf_thread`.`thread_id` = '46219')
Run Time: 0.000799
WHERE (`xf_post`.`thread_id` = 46219) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001771
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 6 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (789106))
Run Time: 0.002125
SIMPLE | xf_attachment | ref | content_type_id_date,content_type | content_type_id_date | 31 | const,const | 5 | Using index condition; Using where |
Params: 46219
Run Time: 0.000095
Params: 0, ٻ
Run Time: 0.000156
Params: ٻ, XF\Pub\Controller\Thread, Index, valid, thread_id=46219, 1715312528, , 0, ٻ
Run Time: 0.000166
WHERE (`xf_session_activity`.`user_id` = 13196) AND (`xf_session_activity`.`unique_key` = '13196')
Run Time: 0.000194
WHERE (`xf_thread_reply_ban`.`thread_id` = 46219) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000242
Run Time: 0.000226
bytes_sent | 12304 |
bytes_received | 278444 |
packets_sent | 124 |
packets_received | 1075 |
protocol_overhead_in | 4300 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 205643 |
packets_sent_command | 61 |
packets_received_change_user | 95 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 77 |
rows_buffered_from_client_ps | 77 |
rows_skipped_ps | 77 |
proto_binary_fetched_bit | 387 |
proto_binary_fetched_short | 133 |
proto_binary_fetched_int24 | 49 |
proto_binary_fetched_bigint | 396 |
proto_binary_fetched_decimal | 29 |
proto_binary_fetched_json | 413 |
proto_binary_fetched_blob | 143 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 204297 |
