Run Time: 0.000377
Run Time: 0.000209
WHERE (`xf_thread`.`thread_id` = '45472')
Run Time: 0.000757
WHERE (`xf_post`.`thread_id` = 45472) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004660
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (763365, 763665, 763816, 763818, 764228, 765144, 765167, 765168, 765298, 765386, 765434, 765435, 765436, 765465, 765665, 765666, 765667))
Run Time: 0.002648
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 17 | Using index condition; Using filesort |
Params: 45472
Run Time: 0.000097
Params: 0,
Run Time: 0.000169
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=45472, 1714744676, , 0,
Run Time: 0.000128
WHERE (`xf_session_activity`.`user_id` = 3903) AND (`xf_session_activity`.`unique_key` = '3903')
Run Time: 0.000217
WHERE (`xf_thread_reply_ban`.`thread_id` = 45472) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000229
Run Time: 0.000219
bytes_sent | 12563 |
bytes_received | 353933 |
packets_sent | 124 |
packets_received | 1101 |
protocol_overhead_in | 4404 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 281173 |
packets_sent_command | 61 |
packets_received_change_user | 121 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 103 |
rows_buffered_from_client_ps | 103 |
rows_skipped_ps | 103 |
proto_binary_fetched_bit | 1225 |
proto_binary_fetched_short | 402 |
proto_binary_fetched_bigint | 1188 |
proto_binary_fetched_decimal | 41 |
proto_binary_fetched_json | 772 |
proto_binary_fetched_blob | 369 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 278702 |
