Run Time: 0.000720
Run Time: 0.000236
WHERE (`xf_thread`.`thread_id` = '17144')
Run Time: 0.000875
WHERE (`xf_post`.`thread_id` = 17144) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002420
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (204782))
Run Time: 0.001540
SIMPLE | xf_attachment | ref | content_type_id_date,content_type | content_type_id_date | 31 | const,const | 3 | Using index condition; Using where |
Params: 17144
Run Time: 0.000117
Params: 0,
Run Time: 0.000126
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=17144, 1715956664, , 0,
Run Time: 0.000096
WHERE (`xf_session_activity`.`user_id` = 12468) AND (`xf_session_activity`.`unique_key` = '12468')
Run Time: 0.000163
WHERE (`xf_thread_reply_ban`.`thread_id` = 17144) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000201
Run Time: 0.000219
bytes_sent | 12317 |
bytes_received | 351242 |
packets_sent | 124 |
packets_received | 1086 |
protocol_overhead_in | 4344 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 278482 |
packets_sent_command | 61 |
packets_received_change_user | 106 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 88 |
rows_buffered_from_client_ps | 88 |
rows_skipped_ps | 88 |
proto_binary_fetched_bit | 440 |
proto_binary_fetched_short | 365 |
proto_binary_fetched_bigint | 981 |
proto_binary_fetched_decimal | 27 |
proto_binary_fetched_json | 682 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 276367 |
