Run Time: 0.000491
Run Time: 0.000180
WHERE (`xf_thread`.`thread_id` = '27803')
Run Time: 0.000548
WHERE (`xf_post`.`thread_id` = 27803) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003524
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (397915, 400236))
Run Time: 0.001111
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 2 | Using index condition; Using filesort |
Params: 27803
Run Time: 0.000092
Params: 0, $
Run Time: 0.000122
Params: $, XF\Pub\Controller\Thread, Index, valid, thread_id=27803, 1714328086, , 0, $
Run Time: 0.000114
WHERE (`xf_session_activity`.`user_id` = 25354) AND (`xf_session_activity`.`unique_key` = '25354')
Run Time: 0.000158
WHERE (`xf_thread_reply_ban`.`thread_id` = 27803) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000195
Run Time: 0.000196
bytes_sent | 12320 |
bytes_received | 359882 |
packets_sent | 124 |
packets_received | 1086 |
protocol_overhead_in | 4344 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 287081 |
packets_sent_command | 61 |
packets_received_change_user | 106 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 88 |
rows_buffered_from_client_ps | 88 |
rows_skipped_ps | 88 |
proto_binary_fetched_bit | 369 |
proto_binary_fetched_short | 364 |
proto_binary_fetched_bigint | 970 |
proto_binary_fetched_decimal | 26 |
proto_binary_fetched_json | 683 |
proto_binary_fetched_blob | 355 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 284933 |
